Key Fob Battery
My key fob gave up working last night so im now using the spare one. Is it easy to change the battery in these things or will i need to take it to the dealer for reprogramming etc?
And how do you get into the key fob, i cant see any screws or anything? :confused:
Is it one of the flip keys or the normal sort?
On the flip ones you need to flip the key open then on the side there is a small tab that you can push in.
The battery is a CR2032 IIRC
Cheers for that. I changed the battery and it still doesnt work. garage couldnt re sync it either so they have ordered me a replacement :)
Under warranty I hope? :D
It dam well better be!
just out of interest, how much if you where payin for it?
  • 3 months later...
I assume that these aren't rechargeble type as in some cars i.e. when u have in ignition?
Nope - I believe there are just the standard CR batteries. Rechargeable is an excellent idea though - which cars have these? :D
Chris
  • 3 years later...
I lost my skoda fabia remote couple of days ago which was working ok. When i tried the 2nd remote, its not working remotely. I have to use the key to lock unlock the car. Although i've changed the battery, still not working.
