Xenon lights, manual adjustment not work enought...
The problem is that the manual adjustment is not enough to make up enough.
Therefore, the adjustment is too low. The other half of the control functions normally easy to find out that the other is somehow out of the act. The control does work well to bring the light close to the other direction, but it really falls short.
Now, if the adjust light up as far as it is possible to loosen the adjusting no longer work in this direction. But, as stated in the downward adjustment is sufficient, but not up.
How can I get the level of control to the upward directing?
I hope you understand what i try to say ;)
Thank you :)
Sounds like the level adjuster has come off. Happened to me a few times. Need to take the headlight out to put it back on.
