Voice Control - Amundsen
Is voice control available in Octy III hatch elegance with Amundsen  ? or Do we have to have Columbus to get voice control ?
Yes. And even multilingual if you change language in setup to different than English.
Works quite well - generally I don't like voice control so, I just check it if exist today :-)
Cheers Arex.
Tested it today Dellfan, and it's really impressive. You can program Sat Nav and also make phone calls from in-device contacts using it.
It takes time, but I find it easier than fiddling with the touch screen on busy roads.
It works - sometimes. I think it has trouble with my northern accent!
is it same like fords sync???
I have trouble with Siri and my northern accent. I try an American one or even cockney sometimes but that Siri knows I'm pretending and still refuses to co operate! I wait to see how "Kit" responds when she's delivered hopefully in September
Tbh the Octavia 2 voice control is better than siri, the new Google now is much better.
sorry but what is siri??? plz help
Siri on Apple iPhone, iPad, and iPod touch lets you use your voice to send messages, make calls, set reminders...
Ali rider,
 Does it have the option of Geordie?
And thou's from posh end o' Yorkshire. Don't know wot it'll do wi my ull accent. Better go an tek the bairns up ginnell to play.
Ali rider, Siri on Apple iPhone, iPad, and iPod touch lets you use your voice to send messages, make calls, set reminders...
thanks mate
I have been trying to find away to MUTE the Nav, and then start it again.
somehow today I managed to mute it, but since then I have not found a command that does it. Any- sensible -  ideas????
Edited by wantaskoda
Cant access the voice-control, only getting an error (Amundsen, Canton etc).
Is it an option, or is it something to call my dealer about?
Edited by mirakulix
I had the same problem the other day. Ideally I'd like the sat nav voice to speak less and pause the music rather than talk over the top of it!
All I've been able to manage is from the settings menu of the set nav, turn the volume of the satnav down to zero. To be honest the sat nav is really good for an incar system but I still prefer running the tomtom on my iphone.
Cant access the voice-control, only getting a error (Amundsen, Canton etc).
If you're using an Amundsen - I just touch the voice button on the unit itself or the voice button on the steering wheel (Elegance model)
If either of those are giving you an error message then I'd have to say off to the dealer with it!
mirakulix
Voice control Does not work i n Norwegian. something they "forgot" to mention in the brochure.. If you want voice control, you have to switch language to English or Swedish..
The spoken words FROM the satnav is supposed to speak in Norwegian, but do not work at the moment. There will be an software update.
Edited by Kabe111
THANK YOU!  :rofl:
mirakulix
Mine speaks in Norwgian - is a femal voice, if I press voice command buttons I get a massage " Voice control not aviable"
PerS
PerS
Amundsen or Columbus?
  • 1 year later...
if I press voice command buttons I get a massage " Voice control not aviable" om my bolero can i enable it on vcds ?
It works ok but, it doesn't deal with swear words very well ! WTF
