air con regas sheffield- any recommendations?
As per the title really....the weather making me really consider getting this done.
Pref a place that doesn't charge you if they can't do it.
kwik fit, if they dont lower temp by a set amount they dont charge.
Only thing about kwikfit is the terrible reviews...
Could do with a trip to tos so anywhere n/around chesterfield would be good too.
theres not too much they can do wrong with aircon though. they need to connect machine up and then press play.
i wouldnt normally recommend them but they did an ac regas for me and were fine
I used Autokool for my aircon as they were the same price as Kwikfit at the time (about £50 I think)
They put the UV dye in for me for free to check for leaks next time and gave the system a thorough check. Aircon's still going strong nearly 6 months later, which has surprised me as there was barely any gas or oil left in the system when I took it in.
If u fancy bobbing up to Wakefield on a satdy morning.. pm me n ill sort u out ;)
I had mine re gassed by kwikfit.  They said the same amount came out as went in so did not charge me.
Kwik fit state in their advertisement that they will guarantee a reduction in temperature of 10%. Wow! that means if the temp is 30deg then they will reduce it to 27- Coool
