problems after new turbo
Bit of advise really. As some of you may have read my turbo went last month in andorra. After collecting the car as soon as I have got it onto the motorway it appears to have a major boost leak. Which is forcing it into limp mode. Not ideal for the trip home. Where do I stand in terms of what I consider a unsatisfactory repair? What would be the normal testing procedure after such a job?
Take it back? Tell them the problem and you want it sorted?
Well if I take it back I'll either be stuck in Andorra and have to get home and back etc. The hassle I had getting there to collect it means this ain't a option. Am I able to go through my local skoda dealership? Obviously skoda dealership is part of skoda. Having owned the car since new I have always had a good word about local skoda uk. Surely there's a procedure that should be followed after such work.
was it a skoda dealer in andorra that repaired the car ?
Yeah. I have the address etc and the invoice for the work. Also paid on my credit card so I guess I could go down the route of complaining to them.
They would have or at least should have road tested the car after the work.
But I have has turbo pipes pop off myself after hand over, crap things tbh.
As the repair wasnt carried out under Skoda warranty it would have to go back to the repairing dealer. But you may find a local helpful dealer that might pop the pipe back on for you.
Ok cool. Thanks for the reply. Like I said the car won't be going back to them, it's to far from home and I'm due on the ferry today. Hopefully have a look now the cars cold. There isn't too many original hoses as the cars running a pro alloy fmic. As to whether I can do a roadside repair is another matter.
Hope it's n easy to reach pipe with just a slight adjustment and jubilee tightening required!
Quick update, spoken to local skoda dealership and they have agreed to investigate the problem. Because it was fixed by a dealership I should have a year warranty on the work. Fingers crossed it won't cost me much more. Obviously ill find out more but cant fault the local dealership with the advice so far... apart from the advise of possible part exchange!!!
  • 7 months later...
Did you manage to find what was causing the problem, i am in exactly the same position! Cheers
I must have seen this scenario dozens of times after a new turbo was fitted.  In every case it's because the garage fitting the turbo didn't know how to set up the actuator and didn't bother their ass testing the car or even checking the actuator and map duty cycle.  I'd be surprised at a dealer not checking it.  But then again, they get a turbo back from a refurb and assume they don't need to set it up.
Thanks for the reply, will find out whether the garage have checked the actuator. What is the map duty cycle? Cheers
I can see this being my next problem, If I ever actually get my car back this year.
