Vacuum pipes help
I've got a 05 plate vrs and was wondering if u can delete the valve things in the vacuum pipes as I want to replace with silicone hose or do I need to keep them in
No, as they are check valves, i.e. one way, if you do the car will go bat**** as there's air where there shouldn't be
Ok thanks I will keep them in then
