URGENT HELP NEEDED....... please
I have removed the instrument cluster to swap the perspecs over as mine had cracked.
Ive sorted it all out and refitted and now car wont start and I get these codes:
Address 01: Engine       Labels: ***-***-***-ASZ.LBL
  2 Faults Found:
18058 -  Powertrain Data Bus: Missing Message from Instrument Cluster
            P1650 - 35-10 -   - - Intermittent
17978 -  Engine Start Blocked by Immobilizer
            P1570 - 35-00 -   -
Readiness: N/A
Address 03: ABS Brakes       Labels: 6Q0-907-37x-ABS.LBL
  1 Fault Found:
01317 -  Control Module in Instrument Cluster (J285)
            004 -  No Signal/Communication
Address 08: Auto HVAC       Labels: 6Q0-820-045.LBL
2 Faults Found:
01299 -  Diagnostic Interface for Data Bus (J533)
            79-00 -  Please Check Fault Codes
Address 09: Cent. Elect.       Labels: 6Qx-937-049-B.LBL
2 Faults Found:
            49-00 -  No Communications
01598 -  Drive Battery Voltage
            07-00 -  Signal too Low
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   1 Fault Found:
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   1 Fault Found:
Address 44: Steering Assist       Labels: None
   1 Fault Found:
Address 46: Central Conv.       Labels: 6Q0-959-433.LBL
   1 Fault Found:
01312 -  Powertrain Data Bus
Address 55: Xenon Range       Labels: 6N0-907-503.LBL
   No fault code found.
Address 56: Radio       Labels: 1U0-035-156.LBL
   1 Fault Found:
00879 -  Connection to Speaker Front Right
            36-10 -  Open Circuit - Intermittent
End   --------------------------------------------------------------------------------------------------
Cant access the instrument pannel or the imobiliser via vcds?
how the hell do I get this shed working again?
really starting to hate this car more and more!
any help would be greatly appreciated
Billy
Check ALL the 'push in' connectors that you had apart, it maybe something simple like they are not fully pushed in.
DB.
If its the same cluster, just with new glass then it 100% sounds like a connector.
if its all plugged in fine then as a long shot id disconnect the battery for 15 min and see if that helped.
Sorted.
Disconnected battery for a bit and now works.
Fyew releife.
Haha did that straight away jus in case.
It has worked ne way mate cheers
Scanning now
Panic over! :)
Hopefully you hate it just a little bit less now m8 :happy:
Jus a tad lol.
Got a few more little jobs to do. Not unplugging stuff tho lol. Really shat me up this morning. Cheers tho guys all faults cleared now and back up n running
