Parrot MKi 9200 Hands Free Kit
As Above, it's around 3 months old, and is boxed with full fitting instructions. Just removed from my Fabia Scout after I fitted Factory Bluetooth.
Great alternative to MDI as it has an SD Card slot incorporated into the display and a remote control that can be mounted anywhere, including the steering wheel, and a connector for USB drives built in as well as a connector for those strangely inferior iphone things.
Read the specs here folks http://www.parrot.com/uk/products/hands-free-car-kits/parrot-mki9200
Bluetooth
  • Bluetooth v2.0 + EDR
  • Supported profiles:
    • HFP (Hands Free Profile)
    • A2DP (Advanced Audio Distribution Profile)
    • AVRCP (Audio Video Remote Control Profile)
    • OPP (Object Push Profile)
    • PBAP (Phone Book Access Profile)
  • Maximum range: 10 meters - 33 feet
  • Pairing: PIN code "0000"
  • Up to 10 paired devices
  • Automatic connection (enabled or disabled)
Dimensions of the screen
  • 72 x 57 x 12
  • 2,83 x 2,24 x 0,47 in
Audio
  • External double microphone, direction is adjustable
  • Full Duplex
  • DSP-3: Echo cancellation, advanced noise reduction
  • Dispatch voice and music on car’s speakers*
Music
  • Multiple connectors: iPods (from fifth generation),
  • USB, SD card, SD-HC card and Line-In
  • Play music from any Bluetooth Stereo (A2DP) compatibles devices
  • Virtual Super Bass
  • Sound Spatializer
  • Digital Class-D 20W amplifier
* Functionality available on the majority of vehicles, however we advise you to ask a Parrot Certified Installer, or another technical car specialists, prior to any installation to ensure that your vehicle does not require any additional equipment to benefit from this feature.
Phonebook
  • Dual Mode (Multipoint): simultaneous connection of two Bluetooth telephones
  • Automatic phonebook synchronization
  • User-independent voice recognition
  • Text To Speech: vocal synthesis of the phonebook
  • Number of contacts: up to 8,000 in total;
    up to 2000 per paired phone
Processor
  • Microprocessor Parrot5 (32 bits) at 208MHz
  • Memory: Flash = 32 Mbits – RAM = 16Mbits
Pack contents
  • 1 Color TFT 2.4" screen
  • 1 Six buttons remote control keypad
  • 1 External dual microphone
  • 1 Parrot Universal Radio Mute box with
    iPod/iPhone & USB cables
  • 1 Steering wheel mounting kit for remote control
  • 1 Dashboard mounting kit for screen
  • 1 Screen cable
  • 1 Mute cable with ISO connectors
  • 1 Set of accessories
  • 1 Quick Start Guide
New they are £149.95
I'm asking £99 Posted to UK via Special Delivery
