What size rims are best?
hey i own a skoad fabia 1.4. can i put 17 inch on my car.. with these rims do i need low profile tires or will regular will fit.....
I will have a set of 16" Fabia vRS wheels coming up soon if you are interested. In answer to your question 17" will fit but that would be about the limit without modification.
To ensure your speedo, etc. is accurate, you'll need to maintain the same rolling radius of the wheel...therefore if you increase the size of the rim, you will need to decrease the profile of the tyre...
Rob.
To ensure your speedo' date=' etc. is accurate, you'll need to maintain the same rolling radius of the wheel...therefore if you increase the size of the rim, you will need to decrease the profile of the tyre...
Rob.[/quote']
I love it when you talk dirty :D
if you can't sell ur wheels as a set would you consider selling seperatly as a few of us would like to replace our spare wheels??
Yes if there are 4 people
excellent, fingers crossed then.
I'm in on spare alloy buying.
damn just seen where your based!! little to far, ah well!
Will look at posting and if there are a few living close together could share postage costs.
If it's less than 20Kg, try parcel2go.com - 8.99 + vat for a shipment via DHL.
I use senditquick.com ,up to 30Kg for
Putting in rims at a size than is more than factory spec is not always a great idea, especially with weaker powered cars like a 1.4. It slows the car down. Looks good, but say bye bye to nippiness.
