Block 004 - synchro/cam timing
Hi,
Presumably this number should stay on what you physically set it.
If it jumps around from 0.0 to sometimes 1.6 (or any number between) does that say something or is it normal.
Thank you in advance
That is normal mine does the same.  Test it after a long drive when the engine is at full temp and it should stabilize a bit more.
