All dash vents the same?
Basically as above... will the right side vent from any year Fabia 1 fit and look the same?
Or did they change them on the facelift in 2005 or whenever it was?
All vents the same in mark 1 fabia.  The only thing which is a little odd is the bits behind the fascia which unclips are often not interchangeable as the middle ones are different size I think, and the side ones have the adjuster knobs on the other sides.
Having seen yours bud, I think if you were to take it off you would actually be able to straighten it up so it works again
