00778 - Steering angle sensor problem
Mark 1, 02-plate 4x4 Octavia.  I've recently developed fault 00778 with the steering angle sensor.  VCDS says simply "no communications", however the display in measuring blocks four of the ABS controller looks entirely plausible (ie 0 at straight ahead, 180ish for a half turn etc etc).  Compared to the other measurements in this block, however, the steering angle sensor reading does seem to update a bit more slowly, every second or two rather than a few times per second like the others especially in "turbo" mode.
Despite having a plausible reading, the fault doesn't clear and the "ESP" light stays permanently illuminated on the dash.
Any ideas?
Thanks,
TKW
Background info:
1) I've seen references to the ignition switch on the Internet.  I did have this out a couple of years ago - what specifically should I be checking?
2) The alternator cable harness was recently changed.  I'm fairly sure it's done correctly but, as well as the main current-carrying cable, there are three multipin connectors.  The four-pin one which goes into the loom near the battery is definitely correct  The other two two-pin ones (one to the regulator on the alternator, not sure about the other…?) I haven't been able to check.  Is it possible to plug these in the wrong way 'round??
3) I've no idea about the codings on these controllers, I suspect some might have been changed before I got the car, so a 2nd opinion would be gratefully received.
4) Full VCDS scan:
Friday,02,August,2013,17:09:03:43659
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: XXXXXXXX   Mileage: 149410km/92839miles
Address 01: Engine        Labels: 06A-906-032-AUM.lbl
   Part No: 06A 906 032 SG
   Component: 1.8L R4/5VT         0010
   Coding: 10700
   Shop #: WSC 23032
   VCID: 75EA57924F6BBDB003D
   XXXXX     SKZ7Z0A1237348
No fault code found.
Readiness: 0000 0101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Part No: 1C0 907 379 F
   Component: ESP ALLRAD MK60     0104
   Coding: 0023174
   Shop #: WSC 31480 000 00000
   VCID: 2D5ABFF2B7BBB570BBD
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            004 - No Signal/Communication
Address 08: Auto HVAC        Labels: 1Ux-907-044.lbl
   Part No: 1U1 907 044 A
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 31480
   VCID: 3064A686F089D89890B
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605
   Component: 0L AIRBAG VW51 0B   0004
   Coding: 12364
   Shop #: WSC 31480
   VCID: E1C293C26BE3A110CF5
Address 17: Instruments        Labels: 1U0-920-xxx-17.lbl
   Part No: 1U0 920 911 B
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 23412
   Shop #: WSC 00050
   VCID: 2E58B8FEEABDCE68827
   XXX     SKZ7Z0A1237348
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 31480
   VCID: F0E4E686B009189850B
1 Fault Found:
            49-00 - No Communications
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0009
   VCID: 204456C6A069681800B
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 3Y Komfortger·t HLO 0003
   Coding: 00258
   Shop #: WSC 31480
   VCID: 3668909E12EDF6A8CA7
   Subsystem 1 - Part No: 1U6959802D
   Component: 3Y T?rsteuer.FS KLO 0002
   Subsystem 2 - Part No: 1U6959801D
   Component: 3Y T?rsteuer.BF KLO 0002
   Subsystem 3 - Part No: 1U0959811D
   Component: 3Y T?rsteuer.HL KLO 0004
   Subsystem 4 - Part No: 1U0959812D
   Component: 3Y T?rsteuer.HR KLO 0004
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1U0 035 161 D
   Component:  Radio GRO         0001
   Coding: 00407
   Shop #: WSC 31480
   VCID: 2A50B4EED655A2485EF
Address 76: Park Assist        Labels: 6Y6-919-283.lbl
   Part No: 6Y6 919 283
   Component: Einparkhilfe        0001
   Coding: 00103
   Shop #: WSC 31480
   VCID: 050A27521F8BAD3013D
End   ---------------------------------------------------------------------
