1.8T Turbo Whistling Noise
Hi all,
Just recently bought a very tidy 2004 vrs. Everything on it is pretty much immaculate, However I have never really done much with these engines being an old 8v GTi Golf freak, Our Vrs when accelerating makes quite a loud turbo noise, It doesnt seem down on power having driven a couple before commiting to buying one but just wanted to check this is normal.
Thanks in advance
Andy
Whooshing = normal (louder with a cold air intake)
Hissing = possible boost leak or leaking diverter valve
Whistling = Turbo might be on its way out
Does the car have standard exhaust, turbo intake pipe & diverter valve? If so, it shouldn't be very noisy.
Are you sure that's not just the noise of the turbo spooling up?
Its just a standard car but makes quite a substantial whoosh when given some pasty!!
its defo not a whistle
I'd say you're fine then.
If you want to be sure, post up a video of the noise that you're worried about.
There is not a lot of sound deadening in the Octavias, even compared to Golf GTIs so they are a little louder...
Exhaust might be leaking at the flexi just after the turbo. Mine did this and it sounded like a drill
Sent from my iPhone 4s
Thanks!!
I would not worry too much buddy as these cars do make a turbo noise when going up the rev range. Quite a few new owners all take a while to get used to it then they love it... :rofl:
Sent from my Samsung S3
Sounds normal; love the noise :-)
Maybe there should be a dedicated place to post audio and video clips of engine noise. I've often wondered if mine is normal.
Certainly normal on mine to make that noise.
