Low volume on aux input with swing radio
Has anyone found a solution to the problem of low volume when connecting a phone to the aux input?
My blackberry plugged into the aux socket, the BB volume at max and the radio volume to max (about 50?) gets the same volume as listening to the radio on about 15.
This would be OK but if I switch back to the radio and forget to turn the volume down first I loose my eardrums!
I've been looking at headphone amplifiers, has anyone tried anything similar?
Or do you know if there a way of adjusting the aux input sensitivity?
There is a way to adjust the aux volume -If I remember correctly you press and hold the right hand knob and it's in one of the menus that comes up
Just tried it:
Yep, press and hold the right-hand button, select Aux, choose level three. Perfect.
Thank you Greenstripe!
I was looking the answer for that question... thanks a lot...:)
TeamPASAOGLU
