Brake pad replacement
i need to replace the pads on my 1.9tdi, any ideas as to a decent set but not mega bucks.
i dont mind paying around
just get some big name decent pads from your local specialist, they will be able to point you in the right direction. probably a lot cheaper than the dealer too
Greenstuff or redstuff.
thanks guys
:finger: If you are doing the rear brakes you will have to use a caliper windback tool or you will break the handbreak mechanism :thumbup:
cheers mate, but im buying the pads and giving em to the local garage.
id proberbly make a whole lot of mess.
cheers anyway.
I'll echo TaviaRS's suggestion - EBC Redstuff or Greenstuff.
Greenstuff aren't much more expensive than OEM pads, and should be OK for road use (rumour has it that they melt or catch fire on trackdays :( ) Greenstuff rears are around
