Dipstick funnel guide replacement?
Having spotted pieces of plastic crumbling from the dipstick, I have bought a new one along with the orange plastic funnel/ guide (as recommended by dealer). I'm just wondering how to get at the funnel and how to remove it. There appears to be a metal plate with pipes attached, which I'm assuming has to be removed to allow access. Will the old funnel just pull straight off and new one push on? Does anyone have any tips for easy replacement of this part? I've only been able to find details on Audi forum, but am hoping somebody here can suggest an easier method.
Thanks for any assistance you can offer.
Been a few years since I last replaced the dipstick tube, but as far as I can remember you just pull it out.
Yeah, you have to undo the 2 allen bolts on the black manifold plate which has tongue that slots into the top of the tube, then the tube should pull out.
If your dipstick tube is self destructing then chances are your crank vent hoses will need replacing as well and it's easier to do them at the same time. If you squeeze the pipes they feel a bit like putty instead of rubber which means they are toast.
Thanks for replies. Only the dipstick itself which is 'shot', as far as I can tell. Will give it a go and post again if further assistance required.
