wind noise at 30 mph + from rear
Hi Guys wonder if anyone else  has had  this problem at 30 mph and above im getting a wind noise from the rear passenger side any help would be great its a 06 vrs , I've checked the rear door rubbers and they look in good condition .
Cheers Matt
I had this turned out to be my rear bearing not that expensive cost me 125 part and fitting not a main dealer
There is an issue with the back door glass on these mate,mine is doing it too and really annoys my lads when they are sat in the back...probs best you do a search ;)
Thanks for the help guys ill look into it.
Sent from my C6603 using Tapatalk 2
Was quite a common issues back in the day.
There were bulletins on it but I think the fix WAS to take the door trim off, slacken the bottom bolt holding the rear 1/4 glass in place and pull hard backwards on the frame and then do the bolt up.
Are thats great cheers for the info mate I'll get to sorting this tonight.
Is it easy to remove the rear door trim ?
Yes
