Wheel bearing replaced
Had the front N/S wheel bearing replaced under warranty and now the steering wheel seems slightly off centre going in a straight line.
Should the dealer have carried out an alignment/tracking check after fitting a new wheel bearing?
Thanks in advance
Phil
Thanks in advance
Phil
Yes they should've but they also charge for it.
Apparantly most dealers outsource this task, or only do a rudimentary toe job.
A proper alignment place should give the most satisfaction/£.
The steering wheel shouldn't go off centre whilst replacing a wheel bearing :(
Should be checked and adjusted after any steering and suspension work has been carried out.
Thanks guys I'll give them a call later today and insist it's done.
