Air intake grille!
I have a mk1 vrs does anyone know if you can get a proper intake grille for the bottom passenger side of the front bumper as my air filter is down there but standard one only has a small hole if so where can I get one?
Wow that still got standard grill !!!!
Either drill out all the honeycombe or Nilotic do a set that look nice
Buy from superskoda
Yea it's drilled out but honeycombe is still there just wondered if there is something a bit different I could buy. I'll have a look now, are you following me Clive? Lol
Milotec do a matching set as Clive said.
Ideal thanks mate had a look apart from it being all in German that will be a plan soon
I just drilled mine out and then cut the bumper away to allow more air in.
Pikey!!! Lol could be a cheap option I suppose
Mines drilled aswell,
not really any other option if you want to keep standard grill unless your hand with a belt sander and sand back away and leave slats intacted
I thought about doing something like that, but after looking at it closely, I decided that would be unlikely to work as it's moulded differently to the drivers side.
You could probably cut the triangles/diamonds out with a Dremel, problem is I haven't got one to try with!
