D2S Xenon bulbs
What's the procedure for changing the D2S xenon bulbs?
I may have a little project on my hands! ;)
Have a feeling that the battery may need disconnecting due to the high voltage igniters!
Disconnect leads, take of ballast, unclips I think.
Bulb should 'just' change pretty much.
Might be able to find something in the bulb-changing bit of the manual (although that avoids xenons, due to safety reasons related to what you already posted :D)
Yeah, the manual says to take it to the dealer! :D
Think there's one connector to the ballast box, so that should eliminate any sort of power going thro' it.
N/S ballast box is screwed to the back of the headlamp cover & the O/S ballast box is under the front slam panel.
I guess there should be some sort of bulb holder at the other end of the lead?
