eml - p0413 secondary air intake swtiching open circuit.
Hi all, I have just replaced my maf and a few split intake pipes and I'm now getting the above fault come up.
Ross tech site doesnt even list it!
Any help or advice appreciated.
Rob
P.s. car is mk1 1.8t 4x4
I am guessing that if you have had the metal plate off in front of the intake that you have a wiring issue in that area, can't remember which one of the small valves under? That plate that controls the SAI but you may have a plug undone or a cable damaged.
P0413 relates to the N112 valve under the inlet manifold panel which controls the SAI. As you say this fault has only appeared since replacing split pipes I'd say you need to look at the small vacuum pipes around the inlet manifold as at least 2 of them connect to the N112.
Edited by pauldazzle
Cheers guys will get back Out and check I haven't disturbed anything else.
