312 brakes and 15" wheels
Will Octy VRS / Golf 20VT / S3 brakes fit inside the wheel?
More out of curiousity than anything else as I can't currently afford to do it!
I'm afraid not.
Not sure you can easily fit 312mm brakes to the PD100 as it uses a different hub assembly :( Have a chat with Jason (Devonutopia) who should be able to give you a shopping list of things you need to change to make them fit......
Chris
Well that solves that then. And I won't feel obliged to spend any cash...
Chris - check your email regarding the hub debacle!
To get 312s on your car, you need vRS outer hubs to attach the calipers to. I believe the existing driveshafts will bolt in to them OK as I believe they use the same bearing assemblies.
Oh, and most important, you need 16" alloys or bigger. :)
