Didn't plan that one too well! SAI removal help!
Hi all,
Was following this guide for the SAI removal and the N valve removals
http://forums.subdriven.com/showthread.php?4893472-DIY-Ultimate-SAI-N249-PCV-EVAP-Delete
Accidentally I have gone too far and have now removed the all the hard lines (not realising that I was entering the EVAP removal part of the guide) Because I didn't plan for that, I don't have any of the hoses, blanking plates or other bits I might need. If I put back together what I have done so far, will I be able to drive the car now? Or do I have to finish it all?
Also, my O ring was buggered inside the plastic water connector. I called skoda to order a new one, but they can't fine the part number. Is there any other numbers it goes under?
Managed to follow it through and release it was the EVAP system I broke into. Was easy to fix after reading robs etka adaptations.
Cheers Rob C!
Just take the lot off, only need a couple of lengths of pipe
