Rear Brake Upgrades
Someone made an adapter to fit 312mm fronts onto the rear and space the caliper out - iirc sold they're octavia shortly after made no more
I've got Compbrake 330mm x 20mm bell/rotor and caliper spacer (StevieWs' old setup)
have a poor pic
256mm rears are not good enough
Does it keep the handbrake line?
Both those setups use the OEM caliper
ie handbrake as per normal
Nice :)
I have 312mm rear disc set up on my octavia.S3 front discs machined to fit S3 rear calipers and homemade adaptors....I may still have the adaptors dimensions but I am away from my pc....
Sent from my GT-I9001 using tapatalk 2
What front setup are you running ?
345x32mm Mercedes Ml 500 discs and EVO 8 4 piston Brembo calipers on custom brackets....Sent from my GT-I9001 using tapatalk 2
Edited by mitsakosgt
Sounds like an interesting setup
My experrience of Evo8 calipers (on an Evo) seem of similar nature to Brembo GT's
But that's a much more useful disk and width
Its a wonderfull setup,IMO its much better than the GT kit due to bigger disc area!
I was going to use porsche cayenne 6 pots but pads are a more expensive than the EVO ones......
