Bolero faults 00446 & 00532, root cause?
Hi all,
I have an intermitent issue with my Bolero in the Octavia. The unit turns off occasionally and the rear parking display sometimes doesn't show on the screen(audio beeps work ok).
VCDS shows the following:
00446 - function limitation due to under-voltage
002 - lower limit exceeded - intermittent
00532 - supply voltage b+
002 - lower limit exceeded -intermittent
Any views on the root cause for this? It the bolero itself likely to be faulty?
Thoughts appreciated
Dodgy battery?
Dodgy wiring?
Bad connection on back of the HU?
Duff bolero?
Sent from my Nexus 4 using Tapatalk 4
If the power supply was low there would be alternatir faults I guess. A bad connection would not usually manifest as low voltage? Perhaps worth an investigation behind the HU
