Turbos
I need advice.
How much is a decent turbo package and what does it usually consist of?? I'm thinking piston heads, sparks, throttle bodies and ECU remap will be required for the car to bear the pressure?? How many horsepower can I get out of a turbo, and I don't want those big ones in Skylines because they have way too much turbolag.
Advice please?
Go for an ickle one. Not sure of the layout of the new 2.0 TFSI block, may be possible to adapt what you have on yours to take one of them :D
Ickle? You mean small??
Fine I already knew that, but you guys have turbo'd cars so you would know what upgrades are needed with a turbo kit right??
Or would a supercharger be better where I'll never have lag?
i would have thought that the cheapest and easiest way to go would be to drop a 1.8T in there rather than turbo your 2.0?
and yes if you wanted a decent amount of boost you would *probably* need new rods, pistons, valves, gasket, manifold, down pipe, exhaust, turbo, management, injectors, fuel pump and probably more that i have forgotton/don't know
There is a supercharger conversion available for this engine somewhere.. will have a look..
Yeah the trouble is the 2.0l is not designed to take a turbo, so it would only be able to run relatively low boost without strengthening the engine. As Bengie said, better off just dropping a turbo lump in it directly - big turbo will be more bhp, small turbo will reduce lag, but will run out of puff quicker. Hybrid may be an option to get round that? Or a twin turbo set up :D
Supercharger requires drive to generate power whereas the turbo's use exhaust gases.....
What you thinking of doing? ;)
Chris
Go down the 1.8T route, cheap and easy go gain more BHP, 265 is simple and cheapish then add a big turbo.
that charger kit would see you to about 170bhp, just drop a 1.8T in i say
After all the :hihi: you give us vRS owners regarding turbos!! :rofl::rofl:
I'm with everyone else, would be better to drop in a 1.8T lump, at least you know your getting something with available spares, reliability, more power etc...
Or just buy a proper vRS.
But he like the Fabia and doesn't want an Octy :confused:
:orb_sword
I'm with everyone else' date=' would be better to drop in a 1.8T lump, at least you know your getting something with available spares, reliability, more power etc...
Or just buy a proper vRS.[/quote']
I gave you the :hihi: because you're drivin' cars with truck engines ;) If there was no turbo in it, it wouldn't move, unlike NA petrols ;)
Chris I was thinkin' of just adding a turbo with necessary engine mods to cope with the boost, but then again with the figures you've given me it makes more sense to have an engine transplant and stick the Octi vRS turbo engine in my car instead. How much would that cost??
And I actually DO like the Octi vRS, and I very much prefer the output of that car's engine to the Fabia vRS and the fact that it's a petrol is even better (no offense to diesel owners).
I don't know...maybe I should just leave the car as it is, and when the time comes, sell it and get myself a Honda Civic Type-R. OR, I could get a supercharger for my car, and since it runs off a belt off the crankshaft. I won't have lag. Instant power, much lower cost compared to turbo, though it ain't as oomphy.
Man, I wish I was in England to meet you guys. It would be cool to talk in person and compare and race!!! :D
Wouldn't be much of a race in my case :(
Or should that be :haha:
You decide :cool:
As for the supercharge, it takes power to run it, eg on the merc SLR it takes over 110bhp just to run the supercharger :eek:
You decide :cool:
You'll never know ;)
I'd also say that it would be cheaper and more reliable to drop in a 1.8T than try and turbo a 2.0l.
You are going to need manifolds, heads, strengthend internals, sensors, custom ECU, etc etc. and thats before you get into reliability issues. Would be far easier to get a full 1.8T complete with all the electronics and make it fit.
As for the Skyline, ever driven one? Standard the have a sequential setup with small turbo first that spools up quickly. They suffer very little lag.
Only above about 400bhp does the standard setup become a problem and only then do you need a large single turbo.
Lee
Or go for a twin turbo with one small and one big to minimise lag and blow power up :D
