s100 brake and clutch master cylinder required, where to get one from
My brake and clutch cylinders are now weeping, so where do you get a new one from or a seal kit. Would the 19mm Estelle seals might fit?
Also my handbrake pawl jumps off the side of the rachet. I an thinking of either taking the slack out of it or/and welding a bit to make the pawl wider.
I have replaced the front calipers and discs, so hopefully I can get her MOT'd and back on the road after a long lay up.
Get in touch with Skoparts Int......
Any pics of the car you have..Probably got one you can have if that helps..
