Epc
Im having a problem with my Octavia Vrs when cornering the epc light is coming on and the brakes are coming off and on when turned off I have no problems can anyone shed any light on this problem
Isn't that the stability control cutting in? Or have i read that wrong?
Are tyre pressures OK?
Sounds like the system is detecting a speed difference between the wheels and trying to control it.
I think it uses the abs sensors so possibly a faulty sensor.
I thought it may be a sensor but not sure
EPC is to do with the drive by wire system, ESP is the stability program, so which system do you suspect is playing up?
