Octavia VRS Fault codes help.
Hi all.
I was looking for some advice on Engine fault codes.
The yellow engine warning light is on and I have the following codes:
16486 - Mass air flow (MAF) sensor, bank 1 - low input
Possible Cause:
Intake leak, air filter blocked, wiring short to earth, fuse, MAF sensor
17544 :: Long term fuel trim, idling, bank 1 - system too lean
Possible Cause:
Fuel pressure/pump, injector(s), intake/exhaust leak, AIR system, hose leak
17705 :: Turbocharger (TC)/throttle valve, hose connection - pressure loss
Possible Cause:
Hose connection
16891 :: Idle speed control (ISC) system - rpm higher than expected
Possible Cause:
Throttle control unit
I'm wondering if 17705 is the root cause of all of these? If so where do I look?
Many thanks in advance.
Edited by MLH
A bit of a google suggests 16486 might me a more likely root cause.
Is that a reasonable assumption? Should I be looking around the air intake? Perhaps checking the Air Filter?
The car does seem to idle a bit randomly, usually a bit slow, sometimes a bit too quick.
Sounds like a boost leak, or split pipe between the MAF and turbo. O
More questions.
Elsewhere it's suggested to disconnect the MAF and see what happens? Is that a good plan? Or does the 16486 error mean all information from the MAF is ignored already and therefore disconnecting will have no effect?
I've had a cursory look at all the pipes I can see. Nothing looks split - in fact they all look good.
Could this simply be a blocked air filter?
TIA!
Edited by MLH
Thanks. I'll have a better look.
If you need any help, I'm only in Bognor and I'm a mechanic  :rofl:
  • 4 months later...
You still stuck with this mate?
Check the y pipe at the rocker box for holes - system is seeing unmetered air somewhere and putting up system lean warnings. Split boost pipe is also a good call.
Also, when was the throttle body last cleaned?. I would clean down the codes, run the car and see which ones return, as you may not know how old some of those codes are.
Hope it helps
Phil.
