Electric mirrors?
Right, am I being a bellend here?
When operating my right wing mirror the left one moves also? What I mean about that is that when I move it left, it moves left with the right mirror and visa versa.
Left one moves independantly, so no problems there.
Now I'd like to say this is some German witchcraft to enlighten my driving experience, however, I'm pretty sure this isn't normal?
vRS by the way.
Edited by Bcc212
Do you have maxidot? You can change to individual wing mirror adjustment in the menu.
vRS by the way.
This is completely normal behaviour.
I believe it is so that if you need to quickly adjust the mirrors, such as reversing, you can do it more easily.
Just set the drivers one correctly then do the passenger side.
As stated by Welsh_kai_boy if you have Maxidot this can be changed so that the mirrors always adjust individually.  One of the first things I changed when I got my car.
via maxidot......
Edited by JR RS
Unfortunately I don't have maxidot. Which is a bit of a shame really as it makes my big, white, intimidating, fast vRS feel a bit of a poverty spec model. Nonetheless, it does the job.
Cheers men.
If you find someone near you with VCDS they should be to disable it.
Sent from my Nexus 4 using Tapatalk 4
