Gearbox fluid change
Hi buddy yep.
identical for the 5 speed box.
Use genuine stuff else you will knacker box aswell
IIRC, the SDI has an 02K gearbox, so the filler plug is on the end of the gearbox - not the side. The plugs are the same but the torque on the 02K is 25Nm.
Thank you all for your swift replies.  I'll be using the genuine fluid too, picked it up today.
I was concerned I may have to fill it under pressure as opposed to the method as described within Bowders1 article.
Thanks a lot chaps.
