Carbon wrapping the dash vents, problems, PLEASE HELP
Hi guys
Ive been trying to wrap the dash vents but have hit some problems.
Here is what ive got so far
The problem, as you can see, is the inner vent bit. The bit with the blades. Im a bit of a n00b to wrapping but ive done ok until now.
The issue is that I cant get enough wrap around the inside bit of the vent. There must be about 2mm before I hit the blades and I have NO idea how to get a clean look. I dont know if its better to cut it off at the edge (like I have tried to) or wrap the 2mm inner bit. From things ive seen, it would look better to wrap the inside too.
PLEASE guys, suggestions??
Two options really.. Either take the vent apart and wrap it all the way around or get a SHARP knife and cut flush to the edge.
How hard is it to take it to bits? Id just need to remove the fins really. Is there any info on doing this?
