what to change with clutch/dmf?
Going to be changing my dmf very shortly, what else is worth changing whilst box is off? When the clutch was changed 12 month ago it was only the pressure plate and friction plate, no mention of bearings etc. Just want to make sure i only do the job once! Thanks
Providing the clutch is ok just the DMF, but I'd throw in a new concentric slave cylinder to be safe.
Hoping clutch is ok, should be probs done 10k tops. Have ordered dmf, bolts and slave cylinder :-)
What clutch did you get and are you stage 2+?
Its a Sachs organic clutch mate, yes stage 2+
