Are these Vag com logs ok?
Well yesterday I had a bit of time to do a fault code scan and a log of boost in third year.
Just wondering if someone can look through the log and see if its ok? I only logged boost pressure so not too sure if any more info is needed??
i have cut out the bits that say no fault
Vag com log.csv
Address 01: Engine        Labels: 038-906-019-ASZ.lbl
   Part No: 038 906 019 LA
   Component: 1,9l R4 EDC G000SG  5405
   Coding: 00102
   Shop #: WSC 13765
   VCID: 61C212EEEB9EBC16E0B
   TMBWU46Y944048579     SKZ7Z0D2386155
1 Fault Found
17911 - Load Signal from Alternator Term. DF
            P1503 - 35-10 - Implausible Signal - Intermittent
Readiness: 0 0 0 0 0
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Y0 820 045
   Component: Klimaanlage        X0830
   VCID: F2E0EDA2BE78B78E091
1 Fault Found
01596 - Motor for Outside/Recirculated Air Flap (V154)
            30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25738
   Shop #: WSC 13765
   VCID: 3C7C839A2CBCB1FE93D
1 Fault Found
01598 - Drive Battery Voltage
            07-10 - Signal too Low - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 601 A
   Component: 0S AIRBAG VW51      0008
   Coding: 12371
   Shop #: WSC 13765
   VCID: 1E3869129A60C3EE9D9
1 Fault Found
00532 - Supply Voltage B+
Two of those faults - Load signal from alternator and drive battery voltage (possibly the airbag one too) could be caused by the wiring loom at the front of the gearbox starting to break.
Or you may just have a battery that needs charging up.....although the load signal fault is nearly always the wiring in front of the gearbox failing.
As for the Recirc air flap fault, I have this exact same fault on my PD100. I keep clearing it and it keeps coming back, although the recirc/fresh button seems to work normally. I assume it is a intermittent fault with the motor, but while it still works I just ignore it.
Clear all the faults and scan again in a week or two.......sometimes random faults are generated and never reoccur when cleared.
