Heko wind deflectors mk2 Octavia
Hi guys I brought these new But order the wrong ones these are the ones which stick to the outside of the car cost me £30 will let them go for £15 + p&p or pick up from Chichester. Area.
Cheers matt
post-105850-13793396348156_thumb.jpgpost-105850-13793396620945_thumb.jpgpost-105850-13793396879429_thumb.jpgpost-105850-13793397207022_thumb.jpg
Sent from my C6603 using Tapatalk 2
Anyone won't these :-)
Are you sure they are stick on ones? I though all Heko ones were in-channel?
If they are in fact in-channel then I am interested.
Paul.
TBH looking at those are you 100% sure they are stick on???
The 10mm thin edge looks like the lip that goes into the window rubber/channel.
I'm probably totally wrong as you must have the fitting instructions that came with them, which show something else.
On closer look can see the red tape on the wrong side for channel type.
Edited by Defenderben
P&P to Redhill?
These are the correct ones. The 1cm section is the bit that slides into the window channel. This section should have some double sided sticky tape on.
These will not stick on the outside. As far as I'm aware Heko do not produce the stick on type, only the in channel ones.
Are these still for sale? Local to Chichester so would be happy to pick up..
Guys please these do stick on the outsside Sandi no this cos I have the correct set fitted to my car now.
Hi mate yes I still have these
I did ask about postage. Seems to have been missed.
Sorry mate will be about £5
Still up for grabs then?
Yes bud
PM'd
