Squeaky Brakes
Hi
I have a 2003 Fabia 1.4 16v Combi Automatic and the brakes squeak when the brake pedal is lightly pressed, they also squeak a bit when I release the brake pedal.  I have had the brakes checked and calipers cleaned and all is well with plenty of meat on the pads however, the brakes still squeak now and again.  The garage told me it could be down to the make of sintered pads fitted by the last owner as some make are prone to squeaking.  Any suggestions on the best make of pads to fit?
I don't have the detailed knowledge of the Furbie you need. I can at least confirm that the garage's opinion is reasonable, and I have no connection with you, them, or any brake manufacturer.
