clearing an engine management light onSkoda Fabia 1.4mpi
Anybody know easiest way to clear engine management light on Skoda Fabia hopefully fixed problem but need to reset before running do I need any special kit ?
You need to plug in with a code reader to read and then erase the code.  The light should go out after a number of driving cycles if the fault has been fixed.  Some lights like the airbag light won't go out on their own and require that the codes are erased.
