Wheel fitment Check
Will these fit a 2012 vrs? For the winter tyres
http://bit.ly/15qEPrv
Not sure to be honest. They certainly won't fit all the cars listed in the advert though as they will not clear a 345mm disc on an S3.
I'd just get steels.
They should fit - the standard vRS spare (if you spec one) is a 16" steel, so they should clear the front brakes.  To be honest I'd rather buy a second hand set of OEM alloys.  They may not look quite as pretty but they're more than likely much stronger, and you can carry on using the OEM bolts with them too.
I do have a standard OEM set but they're not very pretty. Might just get then refurbed then rather than buying a set of copies
