Mk1 octavia spider centre cap size
What size centre caps will I need for 17 spiders?
55mm
Cheers guys
Quick tip if you've not already fitted them.  If you drill a hole in the middle of the old wheel centres (don't drill too far, for obvious reasons!) you can prise the old wheel centres out of the wheels with a screwdriver or such like without the hassle of removing the wheels to push them out from behind.  Then just clip the new ones in.
It's amazing how much difference the new wheel centres make to the alloy wheels, especially if your old ones had almost worn away like mine had.
The new style ones look well, they seem to suit the wheels better than the old ones, strangely.
