CAN Gateway - 7N0 907 530AF
I have for sale a new CAN Gateway part no: 7N0 907 530AF.This is the latest one which superseeds all the 1K0 Gateways.This unit is needed for pre-FL <2007 Mk2 Octavias wanting to retrofit Bolero RCD510 & Columbus RNS510 Head units.
This unit has been pre-coded for a 06 vRS although could be re-coded to suit other cars
I am looking for £75 incl postage or £70 collected from Southampton
I'm looking for CAN Gateway so that I can install Columbus RNS510 Head unit currently have got a Part No SW: 1K0 907 530 E    HW: 1K0 907 951 Component: Gateway H09 0110. I believe this is already coded will it fit my 2005 Octy 2.0 TDI PD?
I honestly don't know if it will work in a TDi . It was coded for my TFSi
Yes that will work in your car Arthur.
Thanks Wardy. I thought it should as its not going to have any engine specific stuff in it as that will all be taken care of by the Engine ECU. Isolating each type of part is logical design
Keep hold of it until the end of the month I will definitely buy it off you. If it goes in the mean time I will have to get it elsewhere.
You're welcome. That's a good price for a current revision gateway.
Will just need coding up with VCDS to match the equipment fitted to your car, as you're probably already aware.
  • 3 months later...
Reduced as part of a garage clear out
Have you still got this ?
Yup still available
  • 6 months later...
Is this still available?
Yup, still available as I found it while boxing up stuff in the garage the other day
  • 11 months later...
Still available now £50 delivered
This is an impressive length of time for a classified ad to run :D
GWLS :thumbup:
Its the effect of having twins and loosing all my free time. At long last managed to do a bit of a tidy up of the garage and found this so thought I would try and see if i can sell it.
Open to offers
