Problems with the covers on depo headlamps
Hi all,
I cannot get my headlamp covers on my xenon headlamps. I've turned my d2s bulb adaptor 90 degrees, but the cover will still not go on. Looks like it's trapping the d2s lead.
Anyone else having this problem?
Thanks, Ollie
Hi Ollie
Did you see my reply the other day on your other thread? http://www.briskoda.net/forums/topic/290596-main-beam-for-d2s-xenon-depo-headlamps/#entry3453341
The back plates are an absolute pain to fit I have to say. I had to trim both the two little legs at the bottom of the plate to make them thinner, and also had to enlarge the holes the legs fit into to allow it to clip properly into place (even now it still requires quite a bit of force to do so)
My D2S adapters are positioned so that the lead points downwards once fitted, that gave enough room for the lead to curl round and exit the hole in the backplate.
Hope that helps
Rhyan
Hi rhyan,
That helps a lot! Thanks, I will give what you did a try and see how it goes :)
Ollie
No problem! :)
Hope you get it sorted. If your still stuck though, I see one of your locations is Cov, so if needs must drop me a PM as I'm only 30 mins or so away from city centre
That's brilliant, thanks very much :)
