Anyone help with VCDS Settings.......
...I'm after some settings altered on my Octavia MK2 FL Vrs
1, DRL's to dim on the side when using that side turn signal
2, Rear lights on with DLR's
3, Cruise displayed in the dash.
4, Coming home/leaving lights, " is this possible ?"
5, anything else you think I would like
Car at the moment is in Aussie Mode
Can the same VCDS software for an Octavia be used on a CitiGo as I need some alterations done on the wife's
Beer/Lager/Cider/Wine tokens at the ready, might even stretch to a bottle of scotch
Thanks Andy
( live in Harrogate ) but can travel within reason
One of the questions that will come up with this one is: "Do you have auto-lights?"
If not, I seem to recall that the car, once coded, will happily light your way even in broad daylight.
No auto light, I'm not right fussed if it can't be done, bit daft having coming/leaving lights in broard daylight,
THanks for that anyway
This is dealer (VAS / ODIS only IIRC)
This can be a bit hit and miss as it doesn’t work on some but does on others.
Yes VCDS will work on the CitiGo, obviously being the entry model there are less things that can be changed though.
If you haven't already then take a look at the VCDS Owners Map in my signature  :thumbup:
