Scan on a Yeti
I scanned another member's Yeti the other day and got the following: (AutoScan with a MicroCAN)
Thursday,17,October,2013,10:47:06:52352
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chassis Type: 5L (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 56 62 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 933F400E09290102C90E02EC901E8082300000
   Shop #: WSC 33361 790 00999
   VCID: 7BDB14D1FA29E0C6C11-802E
No fault code found.
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 48000AB8A05BF1C040080082110001E4430000AE724D81605C8140000040
   VCID: 3A55D1D5B59319CE9A7-806F
   Subsystem 1 - Part No: 5L2 955 119 A  Labels: 1KX-955-119.CLB
   Component: SK356  26  0604
   Coding: 00F7B5
   Subsystem 2 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
4 Faults Found:
00059 - Terminal 30 for Interior Lighting
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 182
                    Mileage: 20437 km
                    Time Indication: 0
                    Date: 2014.14.13
                    Time: 11:56:19
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.25 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00985 - Right Tail Light (M2)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 182
                    Mileage: 20437 km
                    Time Indication: 0
                    Date: 2014.14.13
                    Time: 12:32:15
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00988 - Lamp for Brake Light; Right (M10)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 182
                    Mileage: 20437 km
                    Time Indication: 0
                    Date: 2014.14.13
                    Time: 12:33:06
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01518 - Bulb for Back-Up Lights; Left (M16)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 182
                    Mileage: 20437 km
                    Time Indication: 0
                    Date: 2014.14.13
                    Time: 12:33:12
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RAHTU4C
   Coding: 00005442
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 3147F6F960E5DA962BD-8064
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME5B30706CZZZ.
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME2D34706CZZZ+
   Crash sensor for side airbag; rear driver side:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME62351004ZZZC
   Crash sensor for side airbag; rear passenger side:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME6C110F58ZZZ/
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20120403801781
   Coding: 108A140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79D70ED9F815D2D6D3D-802C
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5L0 920 940 K    HW: 5L0 920 940 K
   Component: KOMBI         H06 0607
   Serial number: 00000000000000
   Coding: 420E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 3449FFED9FF7EFBE40B-8061
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 300312F1000226
   Coding: 356303
   Shop #: WSC 33361 790 00075
Address 22: AWD        Labels: Redir Fail!
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   Shop #: WSC 00000 000 00000
   VCID: 45AFB2290C6D6636E75-8010
Address 25: Immobilizer
Cannot be reached
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3T0 035 192 F    HW: 3T0 035 192 F
   Component: RNS315-EU   H36 0263
   Serial number: SKZAZ2M9251677
   Coding: 020004110403000000000002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   Data medium:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_0038  0038
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 D    HW: 7N0 959 793
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000125927594
   Coding: 011402208001231004
   VCID: 43ABAC31C2595806C91-8016
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   VCID: 3753C8E1468104A6659-8062
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 D    HW: 7N0 959 792
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000125956565
   Coding: 011400208001231004
   VCID: 42A5A935DD43510EC27-8017
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-795.clb
   Part No SW: 7N0 959 795 D    HW: 7N0 959 795
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000126073673
   Coding: 010000200001531004
   VCID: 45AFB229CC6D6636E75-8010
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-795.clb
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000126072916
End   ---------------------------------------------------------------------
Seems to be a few issues in there, also a few "cannot be reached" as well Anyone got any ideas?
Also:
The point of the visit was to see if the Amundsen+ unit had DAB fitted. I unticked the box "DAB inactive", when clicking on Do It the system told me "The Request was out of range".
Does the unit have DAB or not?
Thanks all :) :)
Columbus is not DAB. The fault code suggest that the fuse has blown for interior lights wich also affects rear lights.
Sorry my mistake, Amundsen + is not DAB either. Have you checked the fuses ?
I don't know if the Amundson is the same as the Comumbus in that it takes two addresses to be 'ticked' in the CAN gateway instalation list: Navigation & Radio.
I've always wondered why this is and it may be something that has been corrected with the Amundson unit (which is backed up by no fat showing in 19 - CAN gateway).
It's just a thought and probably a wild goose chase...
It does sound like a blown bulb / fuse or damaged wire somewhere along the way.
Has the owner been doing any work on the vehicle recently? Any reason to have disconnected the battery or forgotten to replace everything before switching on the ignition?
My friend, seriously, please check your facts before posting. Amundsen+(RNS315) has DAB option too, as did Amundsen and many other VW head units.
I'll check the coding on mine a bit later on the Radio+Navigation front. IIRC all the Radio functions do seem to be under Navigation though (things like having 2nd FM aerial installed for example) and I do recall clicking on Radio tells me that the controller isn't installed.
The car has only been with the owners for a couple of weeks and I suspect that there is a certain amount of reluctance to take the DIY approach on any updates. ;)
