Which Bosch Aeroblade wipers?
Side pin fit (if you have newer wiper arms which you should have).
To find out turn the ignition off then press the wiper stalk down. The wiper arms will come up and stop.
Lift the arms way from the screen, twist the wiper blade 90 degrees from the arm and see if it slides off a 'pin'.
Either way you'll know what you need.
side pin.
i got these recently - Bosch Aerotwin A937S
Designation = Wiper blade Aerotwin, set
Fitting instructions = GWB006
Independent aftermarket part (IAM) = 3397118937
Length/wiper blade 1 = 600 mm
Length/wiper blade 2 = 475 mm
Type of attachment = RBSL1.1
Edited by JR RS
