Sunroof & radio
2 questions
How do you operate the sunroof, does the car need to be turned or what conditions must be met.
Can the radio be turned on when the car is not on. I have kessey and a Columbus
Dont  know and Don't know, sorry I can't help.
Someone will be along shortly who'll know    :yes:
Hopefully
The radio can be turned on when the car is not, If you leave the stereo on and turn off the car the stereo stays on until you open the driver's door and will come back on when the car is switched on. The sunroof won't open when the car is off except for tilting in combination with the windows opening when you press and hold the unlock button on the keyfob (if programmed to do so in the car menu) The sunroof will close on the key if you press and hold the lock button even if it is fully slid back.
With Kessey  -to switch the ignition on without starting the engine -just press the start button without putting your foot on the clutch
