vr6 clutch kit part no
does anyone have the part no for the vr6 clutch kit at euro car parts please
also can anyone tell me is it essential to change from dual mass flywheel if u fit this kit as i no g60 smf is the one to have but darkside kits and awesome are just a little out of price bracket
Personally, just go for the solid flywheel kit for the vrs that euro car parts sell. I have read a few people on here using them without any issues and a few were running stage 2. This is a valeo kit too, whereas the other kit (made by techniclutch)  is very dodgy from what I have read on various car owners clubs online.
http://www.eurocarparts.com/ecp/c/Skoda_Octavia_1.8_2002/p/car-parts/car-transmission/clutch-and-associated-parts/solid-flywheel-conversion-kit/?633780010&1&df9020a9bc4935a972dd7dc096659fb48f0023d0&000299
no really want to go down the route of g60 fly smf and vr6 clutch if possible just need to no part no and if its essential to change the fly on the vr6 clutch or if it only fits on the smf as i have looked at there kits and if u use car parts 4 less u can get the kit u are talking about for 180 as opposed to 212 euro car parts want for it so i have looked at this option worse case scenario
That's fair enough mate. Thanks for mentioning car parts 4 less, that will save me money when I go to buy the valeo kit next week for my vrs  :thumbup:
Euro car Parts have a great offer on parts at the moment
i just bought a Sachs VR6 clutch kit for £105 delivered and it is great.
Sachs are top notch slight upgraded to OEM
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.8_1996/p/car-parts/car-transmission/clutch-and-associated-parts/clutch-kit/?641440660&1&6643cb8ec925144d748b13885cae01617b3c98e6&000069
Also if you used this voucher
AUTUMN25
You may even  get 25% more off which makes the kit around less than £93 delivered not bad eh.
The Euro Car Part number of the kit is 641440660 for the above 228mm clutch needed
flywheel bolts: N 902 061 03
press pl. bolts: N 101 010 01
The G60 Flywheel  is only around £100 i think direct from VW.
P/N of Flywheel is 037 105 273C.
or you can get the whole kit as a Valeo Flywheel / Clutch and al bolts from above thread link or your parts for less
u sure they the right part nos mate as rang vw stealers and they didnt recognise part no for flywheel said the flywheel bolts were 33 pound each and press pl bolts were 33 p screws
not to worry phoned tps and they recognised all part nos but flywheel but i found this was right
G60 Flywheel = 028 105 269 BX
Good Job
All those P/N should of been ok.
And I would not expect £33 per bolt lol....
Glad you got there in the end mate.
thanks for the help mate can always rely on your advice :D
does anyone have the torque settings for the flywheel and clutch pressure plate bolts as we will be attempting to fit this at weekend and just want to make sure we have right settings does this look about right to you bowders mate
Flywheel bolts are 60NM + 1/4 turn
Pressure plate bolts are 20NM
Hi Buddy this is spot on .
Flywheel bolts are 60NM(44lbs) + 1/4 turn as stretch bolts(can also add screw thread compound)
Pressure plate bolts are 20NM(14lbs) .
