Is this normal?
Is it normal to have this much built up on condensation inside the windscreen?
It was rather heavy condensation almost like water droplets inside the car, the car had just been washed at this point but other cars iv had have not steamed up this bad?
Is this generally what all fabia's are like or is there an issue I need to look at?
kev
Leaky door seals im afraid but easy to fix :)
A search will bring up everything you require ;)
Ah okay cool, il have a search on that one, are they easy enough to be  DIY job?
Yup :)
Did the rear door seals earlier this week and wow there was a lot of water in there! Now all sealed up with plumbers gold and so far so good, just waiting for some heavy rain to double check everything is ok.
The water under the carpet will still cause the windows to steam up for a while, i usually park up for 10-15 minutes with the heaters on full blowing into the footwells every couple of days
Used Vax on the rears to suck the water up
