ecs n75 valve
Whats peoples views on this may be buying one but wanna make sure will work accordingly on my octy vrs
Waste of time IMHO...
It will just give a bit if a spike in boost,that's all,as there "lazy"
My cousin gave me a race n75 for my birthday :)
Seems cool, went on with my kona kit and defo seems alot quicker from down low
I think some cars and maps like them and some dont
Lots of wonga tho and they have gone up
I have one fitted and they do make certain cars retain a better boost curve.
generally i would say if you car has good boost and no hesitation then not really needed and can sometimes cause boost spiking on a car that is already running well.
I had hesitation and the race N75 cured that for me :thumbup:
What's the dirrerence between the race valve and the j valve from what I have read both do The same job
They do the same job as they are both N75 vales  :rofl:
But the ECS race valve is actually a H valve and the J valve is what is on Audi S4 and RS4's and LCR I beleive
It is just a signal difference with the ECU
The N75J and H valves provide a sharper boost spike over the STD F valve and gives a little more psi, H valve  can cause limp mode
It really is a mixed feeling with these. Mine runs better with H , never tried the J
From what I can tell H works better with AUQ engines and J works better with BAM engines
Dont suppose you know the part numbers for both valves do you
