Amundsen Sat Nav
Will the dealer give me a CD or SD car with this?
Does the CD or SD card have to stay in all the time, or just when installing?
And how about updates, how do they work?
No    If you want an update it will cost you about £120/160
I use my SD for music
The maps are on a hard drive within the Amundsen unit itself, not on an SD card or CD.
Ok, so I shouldnt expect any CD or anything.
No free updates though? That's a bit naff.
There's no update for the sat nav at the minute, would be downloaded via VCDS or a disk possibly if needed.
Sweet talk the dealership when it goes in for a service, especially if you've got the service plan, they might include the update if one was available.
It's going to come with the latest maps available anyway so you won't need to worry about updates for now.
That's the problem with intergrated sat navs, they can't easily be updated like TomToms and Garmins.
24 Range selector key NAV (Navigation)
Note
All dtns. (country-, village-, road-, point of interest names) must be entered including
all country specific (or language-specific for points of interest) special characters.
Navigation data, navigation CD and memory card
Inserting the navigation CD
– Push a navigation CD with the written side facing up as far as possible into the CD
case until it is automatically drawn in.
– If you wish to take out the navigation CD, press the button .
Update navigation data
– If the data of the navigation CD is not identical to the data on the SD card, a corresponding
message will be displayed.
– Press on the function key to overwrite the data stored on the SD card with
the data from the navigation CD.
Store the navigation data from the navigation CD onto the memory
card
– Push the memory card into the card case .
– Press the range selector key and while in the main menu Navigation, press
the range selector key .
– Select the function key using the menu control button and
then press the function keys and .
The navigation data can be stored either on the CD or on the SD card.
If a SD card with navigation data of the same country as on the CD is inserted in the
unit (however the data on the CD correspond to a newer version), a question is
displayed after inserting the CD asking if the data should be overwritten with the new
version or if only the data of the CD should be used for navigating.
If a SD card is inserted with the cards of other countries than the card contained on the
CD, a question is displayed asking if the data on the CD should be added onto the SD
card or if only the data of the CD should be used.
You can copy data from several navigation CDs onto a SD card. The navigation data on
the SD card are automatically linked by the navigation system. For this reason, we
recommend to use a SD card with sufficient memory capacity. A memory capacity of
approx. 4°GB is necessary in order to copy the navigation data of Western Europe.
Using the data of a navigation CD for a short period of time
If you only drive for short periods through an area which is not stored on the SD card,
insert the navigation CD for the driven area.
Up to date navigation data and new navigation CD
Road guidance is subject to constant changes (e.g. new streets, changes of street
names and house numbers). A navigation CD is a huge data store, which unfortunately
will not be up to date after a certain time. This can lead to complaints during route
guidance.
It is for this reason that you must regularly update the navigation data on your unit with
a current navigation CD.
Remaining function buttons
The following function buttons are only active if a navigation CD is inserted in the unit
and the memory card contains navigation data.
• - displays information regarding the navigation CD (area
and version number of the navigation CD);
• - displays information regarding the stored navigation
data and their volume;
• - opens the menu with which you can delete the navigation
data on the memory card;
• - activates the storage of the navigation data from the navigation CD
onto the memory card.
Note
• Copying a CD can last up to one hour, during the copying the navigation functions
(route guidance, map display) cannot be used, the mode TMC (traffic report) as well as
Does the unit display album art and contact pictures? I just read it did, but not sure if that's the better model.
I have the admundsen rns315 and it does not display album art, just track info.
