removing windows media player 10
does anyone know how to do this and take it back to the normal windows media player cause its causeing problems with videos.ive tried system restore and it didnt work
silly question... but have you tried uninstalling it from the Control Panel, using add/Remove Programs??
i tried that but it just comes up as the normal windows media player on there
Hi
You could have a look here, but please don't blame me if you do anything 'orrible:
http://www.auditmypc.com/uninstall-media-player10beta.asp
Quote from site: "You will use this procedure only when the option to uninstall media player 10 beta, 10, 9, or others are not listed in the add / remove programs under the control panel."End Quote
Regards
Mo
Doing this by any chance ?
and this
I was using Media player 9 when it happened, downloaded 10 and it was still happening. I ended up removing 10 and going back to 9. When I installed PowerDVD it must have had whatever codecs were needed to run Media player as it then worked ok.
Last time I unistalled media player, it rolled it back to the basic edition. I however prefer Winamp....by far better.
tried both those and they dont seem to work :(
Did you check the links? I also sometimes find that PowerDVD is a better access. Have you "uninstalled" by the inbuilt facility? I don't understand how you have not rolled back to 9 by now. But maybe you have? Where are you up to and what have you tried?
Regards
Mo
